06-04-2005, 10:22 AM
TX
Before you run off and buy another battery try charging it on a
charger. If it takes the charge ok then clean the posts and terminals
and hook it back up. Sometimes a loose terminal will be enough
resistance to keep it from taking an adequate charge while you are driving
and it eventually drains down. The loose terminal in itself won't drain it.
Flip
