Thread: Ignore (EOM)
  #3474 (permalink)
Old 06-04-2005, 06:38 PM
blykins blykins is offline
Mike, headers should be your last worry.....there are tons of header kits out there.....you just piece them together and weld them up. Custom headers.
I'm running Vic Jr cylinder heads. I ordered them bare and assembled them with the correct valve springs, shims, retainers, etc. Also, I don't know if this is true for all Edelbrock heads, but the ones I have seen don't have spring cups on them....so I put those on as well.
I'm using a Comp Cams hydraulic roller cam....230 degree duration, .544 lift, 110 lobe separation. I should have went with the biggest roller cam they make.....Desktop Dyno estimated a 57 hp increase with my heads and intake. I have a lot of faith in DD...it was only 2 hp off from the actual dyno results.
Also, from my research in dynamic compression ratios, I could have went another half point in compression with my cam selection.....could have went 11:1 and still run on 93....
Like I said before, don't settle. If they can put a small block Ford in a Sunbeam Tiger, you can put a Windsor block in that Sprint.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
