Old 06-04-2005, 10:05 PM
Tim Brewer Tim Brewer is offline
Cobra Make, Engine: Lonestar LS 427, Keith Craft 501,Toploader
Well really, you don't bleed a non hydraulic clutch. If you can bleed it, it's a hyd.clutch. It sounds like you do have a hyd. clutch and the procedure for bleeding is the some for brakes. Even though you may have a mechanical T.O. bearing, you still bleed the slave cylinder that operates it.
Tim
" It ain't no big deal"
