Old 06-05-2005, 07:04 AM
Buzzmobile's Avatar
Buzzmobile Buzzmobile is offline
Cobra Make, Engine: SPF 148 with 427 SO
OK, it was late last night and a little bit of a trying day. Lets try this again. How do you bleed and adjust a hydraulic clutch that is a NON hydraulic throuw out bearing
Like how far in should the plunger be when I bleed. All the way out? All the way in? How do I adjust the length on the rod conncting the arm to the slave? That kinda business. When I initially set the rod length, should the plunger in the slave be mostly to the rear of the car?
thanks
Buzz
