Old 06-05-2005, 12:24 PM
mgilbert's Avatar
mgilbert mgilbert is offline
Cobra Make, Engine: la exotics 289 5speed 9in. 270hp 295tq w/ g-tech
hey hows it going? i'll take a shot at this, i think you bolt the part to where the a arm used to bolt to the frame. you then take a arm shaft and rotate 90 degrees and bolt to the part that bolts to the frame. so now the a arm attachment bolts are horizontal and you can then use shim g.m. style. the part looks like a piece of angle iron to me. once alignment is right mabey weld to frame? this is what i have read, i need to do it to. i hope this is correct, and some help see ya, Mark
