Old 06-05-2005, 07:36 PM
kmarccoco kmarccoco is offline
Cobra Make, Engine: ERA
Default oil in my cylinder, leaky valve guide?
hi all, i just bought my cobra two weeks ago. it has 351 stroker with aluminum heads(only 5000 miles). well, i was getting a bit of smoke(smelled mostly like gas) out of my passenger side pipe. i pulled the plugs and found the second cylinder from the front(pass side) had an wet oil/gas plug. i took coil wire off and turned it over with plug out. a bit of oil shot out. all other plugs/cylinders were fine.
does this seem like a leaky valve guide, or worse? it has roller rockers and cam. thanks ken
