Old 06-06-2005, 09:14 AM
bkozlow bkozlow is offline
Cobra Make, Engine: built the molds and body composite construction
Wayne,
My guess is it is the coil or the MSD box. Many times electronics fail because of heat. The condition you describe is similiar to a common problem with mid-60's 289 HP engines in Shelby GT-350's. In this case it was bad condensers that broke down as the engine compartment heated up. I belive it is your MSD box. It may have checked out OK when it was cold but did you check it when the engine wouldn't run?
bill k
