Old 06-06-2005, 02:20 PM
2KWIK4U's Avatar
2KWIK4U 2KWIK4U is offline
Cobra Make, Engine: Lonestar LS427, Keith Craft 496 Genesis, 649 hp, 668 ft-lb, TKO-600, Dynatek Stack EFI
Clois,
That is the same Wilwood part # I'm running, and it comes with "Q" pads. I went through their recommended bedding cycle and was very disappointed at the stopping power. The setup is the same as you described except I'm using a Wilwood pedal assy. w/balance bar, and drilled and slotted on all four corners.. I checked pressures and it was good, changed MC's, adjusted B/B every way possible and couldn't lock the front brakes. However, after about 300 miles of everyday driving, the brakes gradually got better and better, to the point that they feel like they should now. I though I may have messed up bedding them but it may be the Q compound? May not been able to build enough heat in them, just don't know.
Brad W.
A good friend will come and bail you out of jail...but, a true friend will be sitting next to you saying, "Damn...that was fun!"
