Old 06-07-2005, 10:32 AM
zipzip's Avatar
zipzip zipzip is offline
Cobra Make, Engine: Midstates work in progress, personally built 302
Here's a pic of the back of my block. You can see the hole you're talking about and what's behind it. Plug or not, it's your choice. It just goes into the flywheel/clutch area.
I don't know the original purpose - maybe some sort of sensor that picks up on the teeth of the flywheel? Or a manufacturing construction hole...
Anyways, I think you can just leave it. I've run my engine without doing anything to the hole - no major oil spills or anything like that.
Hope this helps.
You might be a redneck if you think the National Anthem ends with "...Gentlemen, start your engines."
