Old 06-08-2005, 01:29 PM
Yetiman's Avatar
Yetiman Yetiman is offline
Cobra Make, Engine: Arntz/SBC/Jag
With the MSD setup he doesn't need a balast resistor... but if he indeed has a balast resistor it could be a likely culprit. Could try bypassing it if there is one.
I had an MSD 6AL go bad on me two weeks ago. I had an intermittant misfire as the car warmed up that got worse and worse. The box itself started making noise like ignition noise on a radio (even though i don't have a radio), and finally made a loud pop; and the engine died.
I was running a points distributor, so i was able to bypass the 6al and get home. Mine was not even a month old, and was 'infant death syndrom'.
New box and i'm rockin'... but i installed a terminal block for the wiring so it will be easier to bypass roadside when it flips out again.
We come into this world naked, screaming, and covered in blood. With dedication and a little planning, you can go out the same way.
View my overflow Gallery (much more to come !)
