Old 06-08-2005, 09:54 PM
Rick 427 Cobra Rick 427 Cobra is offline
Cobra Make, Engine: HI-TECH 289 FIA
XKE's use spine drive hubs for wire wheels. In order to mount Trigo or other bolt on wheels you have to change hubs to a flange arrangment. XK sedans use a flanged hub with a chevy bolt pattern. E-type rears are desirable because they are narrow. Sedan rear ends have to be narrowed for a Cobra application. This narrowing process has proved to be problematic for many owners, resulting in total suspension failure. Not a good thing at speed. Get the E rear,change hubs and your set.
I have the fronts also for Contemporary and others using E type front ends.
fiaroadster
