Old 06-09-2005, 04:50 AM
speed220mph's Avatar
speed220mph speed220mph is offline
Cobra Make, Engine: ERA 427SC w/427so, ERA GT #2002
You can do this if you get the car up high enough for access. Layout a level straight line across the flange that is flush with the bottom of the bellhousing. Apply a piece of making tape along this line as a guide and use a cutoff wheel in a die grinder to make the cut. You'll have to protect yourself from all the flying hot particles. Once you've removed the flange and section of engine plate, remove the razor-blade like edge with a burr and file, then protect the bare metal with a nice coat of paint. Nothing to it!
Tom
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough HORSEPOWER." Mark Donohue
