Old 06-10-2005, 09:27 AM
Three Peaks Three Peaks is offline
Depends on what kind of mounts you have, but usually the SBF mounts have a left and right. It only applies to the locating pins, though as they are the same height. See if your engine is setting square on the mounts. You might need to raise one side a bit so the other side can slide down into place.
