Old 06-12-2005, 06:33 AM
Turk's Avatar
Turk Turk is offline
Cobra Make, Engine: What Cobra?
Send a message via Yahoo to Turk
BEFORE ALIGNMENT
FRONT LEFT:
TIRES: GOODYEAR EAGLE SPECIAL 26.5" X 8" X 15" 28 LBS 82.3125" Circ.
RIDE HEIGHT: 3.75"
CAMBER: NEG. 6.25 deg.
CASTER: POS. 1.75 deg.
TOE: POS. 0.0625 TOTAL
SHOCK: PRO SHOCK 15.75"
SPRING: 450 lbs. 10"
FRONT RIGHT:
TIRES: GOODYEAR EAGLE SPECIAL 26.5" X 8" X 15" 28 LBS. 82.3125" Circ.
RIDE HEIGHT: 3.75”
CAMBER: NEG. 1.00 deg.
CASTER: NEG. 0.25 deg.
SHOCK: PRO SHOCK 15.75”
SPRING: 450 lbs. 10”
LEFT WHEEL BASE: 89.75”
LEFT REAR:
TIRES: GOODYEAR EAGLE SPECIAL 26.5” X 10.5” X 15” 28 LBS. 85” Circ.
RIDE HEIGHT: 7.1875”
CAMBER: 0.0 deg.
TOE: OUT 0.375”
SHOCK: PRO SHOCK 17.75”
SPRING: 500 lbs. 12”
RIGHT REAR:
TIRES: GOODYEAR EAGLE SPECIAL 26.5 X 10.5 X 15" 28 LBS 85" Circ.
RIDE HEIGHT: 7.25”
CAMBER: 0.0 deg.
TOE: OUT 0.375"
SPRINGS: 500 lbs. 12”
RIGHT WHEEL BASE: 89.875”
AFTER ALIGNMENT
LEFT FRONT:
RIDE HEIGHT: 4.0”
CAMBER: NEG. 0.625 deg.
CASTER: POS. 3.25 deg.
TOE: OUT 0.0625”
SHOCKS: PRO SHOCKS 10.00”
SPRINGS: HYPER COIL
600 lbs.
TOP LINK: 1 AND A HALF TURNS OUT
RIGHT FRONT
RIDE HEIGHT: 4.0”
TOE: OUT 0.0625”
SPRINGS: HYPER COIL
600 lbs.
TOP LINK: 1 TURN OUT
LEFT WHEEL BASE: 89.75"
LEFT REAR REAR:
RIDE HEIGHT: 5.625”
CAMBER: NEG.0.50 deg.
TOE: IN 0.0625”
SPRINGS: HYPER COIL
450 lbs.
RIGHT REAR:
RIDE HEIGHT: 5.625”
CAMBER: NEG. 0.50 deg.
TOE: IN 0.0625”
SPRINGS: HYPER COIL
450 lbs.
TOP LINK: HALF TURN OUT
RIGHT WHEEL BASE 89.875”
OBAMA IN in 2012
