Thread: Breathless 427
Old 06-13-2005, 12:16 PM
55312's Avatar
55312 55312 is offline
Cobra Make, Engine: E-M 427 Top Oiler stroked to 482 by KC, Stage 2 heads, a Quikfuel and Voila, 640 hp
Default Breathless 427
I need some advice - I currently have an 8.25" air cleaner assembly on my 427 and I know it's just not getting the air it needs. It runs rich and I really don't care about "that authentic look". I can put it on the engine when showing the car (which is almost never). If I believe the K&N formula for surface area, I'm 2/3 short at 6000 RPM. The correct size seems to be 14" diameter by 3" height. The carb is a 650 CFM Street Demon. What is everyone else using for air cleaners? K&N? Rush? All suggestions are very welcome - including part numbers if you have them. The hood clearance is always a problem and the K&N adds 4.67" to the carb flange as a drop base won't fit with the electric choke. I'll see if I have that much clearance after work today.
Thanks
Tim
At first, nothing happened. Then after a few seconds, nothing continued to happen.
Douglas Adams - Hitchhiker's guide to the Galaxy
