Old 06-14-2005, 04:08 PM
tfarhood tfarhood is offline
Cobra Make, Engine: Backdraft #101, 342 stroker
JayBar - Thanks again .
Niles, I never said it was the Master Cylinder, only stated that "if it is" the MC, here is the part number. Also gave the part number for the slave as well. Unfortunately, the owners manual from BDR is almost non-existent. So offering part numbers that aren't from S. Africa are always welcome from BDR owners.
Anyway, if it is "spraying" all over the engine compartment, it should be easy to see if you have your "wife, kid, or neighbor" hold the pedal down while you take a looksee. If you don't see it spraying out of somewhere, then it probably is dripping and only flying up due to the hood being off the car. Your technical explaination of the MC and Slave were good, but the flaming started with you. The bottom line is that we are all just trying to help, and help was asked for. Now, if I said that it is caused by a loose gas cap or a muffler bearing being worn-out, then go ahead and FLAME me.
tfarhood
