Old 06-15-2005, 07:20 PM
Richard Hudgins's Avatar
Richard Hudgins Richard Hudgins is offline
Cobra Make, Engine: Porsche 928 S4
Hi Guys,
Clois,
First, is your pedal effort good now? Can you lock the brakes without a herculian effort?
If so. stay with the same bore size. If not, speak with rdorman.
ItBites
As to system pressures. 1200 psi is more in the correct range at 76 lbs pedal force for non boosted systems.
rdorman
I have not seen the system that you are speaking of. But I have seen many schemes to allow for perfect camber and I think that they are all way too complex.
As every tire manufacturer has different constructions, the camber curve requirements are all over the place.
I just design in curves that make sense and then try to control the masses with dampers and roll bars.
That is the most my small brain can deal with.
Best regards,
Richard Hudgins
