Old 06-16-2005, 12:35 PM
mj_duell mj_duell is offline
Send a message via AIM to mj_duell
Originally posted by chopper
I assume you've already checked this, but you should also make sure that the needle valve is clean and not sticking, nor leaking at the seat. In my experience, the needle valve design of the Holley is one of the weak points of the carb, and I used to carry spare needle valves in my tool kit to change if they stuck or got dirt in them. Any minute piece of trash on the face of the valve will prevent the valve from seating and will cause the carb to flood.
This is the exact problem I had. After changing out the needle valves all was well.
--Mike
