Old 06-17-2005, 06:09 PM
fitzmotor fitzmotor is offline
You might also check if the disc is moving freely on the splines, if you put it in dry and some rust has formed between the shaft and the disc or if the grease has gummed up, the disc wont back away from the flywheel when the clutch releases, unfortunatly the only way to check this is to pull the trans.
