Old 06-18-2005, 01:12 PM
trularin's Avatar
trularin trularin is offline
Member of the north
Cobra Make, Engine: A Cobra
Well, lets see. It is a standard nine inch Ford rear end with either 28 or 31 spline axels.
To remove the seal:
1. remove the rear tire.
2. remove the brakes.
3. there will be four T bolts holding the seal retainer to the axel tube. remove the four nuts but placing a socket through the axel face holes.
4. either the axel will pull right out or you will have to pull it.
5. The retainer is the plate that bolts to the axel tube. It will have to be free of the axel to get to the seal.
6. press everything to the reatin off the axel. 9 to 15 tons should do it.
7. remove the seal and replace with a new one.
8. press everything back on.
9. reassemble the axel into the reaend and check fluid levels.
That should get you through it.
Hope this helps.
