Old 06-20-2005, 06:09 AM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
Default Re: Re: Re: Genesis 427 S/O- First Dyno Pull
[quote]Originally posted by CSX 4027
Originally posted by Anthony
[ I may not call it an all out racing cam, but it is more radical than probably anything ever offered by any the OEM's in the sixties, including the Ford 427's, hemi's, L88's.
Anthony,
The original 427 C3 AA Cobra Cam was in fact more duration than the Comp Cam in this thread. It was advertised at 306. The comp is advertised at 294. That's a difference right there and remember the Cobra's made about 480hp back then.
From what I remember, alot of the "factory" cams had a large advertised duration, but the duration @.050" was relatively short for the given advertised duration compared to afetrmarket cam specs, as the factory cams seemed to have a more gradual ramp. I'm curious, I'll have to see if I can find out the factory cam spec adv duration vs. duration @ .050" which, from my reading is a more reliable indicator of a how radical a cam is. So even though the comp cam is listed at only 294 duration, it wouldn't surprise me if the duration @.050" is actually larger.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
