Old 06-20-2005, 09:40 AM
mj_duell mj_duell is offline
Send a message via AIM to mj_duell
Yup. I had to use slightly longer grade 8's and had to do what Roscoe did with a shim. That changed when I ordered Pole Position uppers and had more control over the Camber/Caster. I am running .75 negative camber in front with Racing tires for track events and .50 for the street. If you are going to do any performance driving with the car I would change out your rear 250lb stock coils for for 350lb units. The car handles far better with the heavier springs and the ride is just as good.
--Mike
