Old 06-23-2005, 10:58 AM
Buzzmobile's Avatar
Buzzmobile Buzzmobile is offline
Cobra Make, Engine: SPF 148 with 427 SO
Here is where I am. I adjusted the pump lever and got that working correctly. I am thinking that I had a lean problem at low RPM because I made it a little richer and *most* of the problem went away. I can cruise at a steady speed without out hiccups. When I get on it, it does not hesitate. Total timing is 38, still haven't checked on the idle timing, but I think a little more advance of initial timing will help. All of what I am feeling is below 3000 RPM. When I am up in the power band a little, no problem.
