Thread: oil problems
Old 06-26-2005, 04:26 AM
Tony Radford's Avatar
Tony Radford Tony Radford is offline
Cobra Make, Engine: Unique 427 SC, Southern Automotive 427W Stroker
When I purchased my stroker, the piston rings lasted a few hundred miles before they were worn away. My carb was so rich, it washed the oil off of the cylinders and caused premature wear. It if persists, have a leak-down test performed and take it from there. My engine was burning a quart per 100 miles and it wasn't smoking. I tried everything for 3,000 miles before I finally took it back for disassembly. I know of others that had a similar problem. If the level is dropping fast and there aren't any puddles, it's got to be going somewhere (and there aren't many possibilities).
After a good hard ride.....oil pressure is over 50, temp is below 190, she idles and no new dents. LIFE IS GOOD!
