Old 06-26-2005, 06:22 PM
lovehamr's Avatar
lovehamr lovehamr is offline
Stolen Avitar
Patrick,
Thanks for the reply. But here we go again.
"With the removable booster deal, you have to use BG boosters as ours won't fit. So you're limited to them."
Is there some sort of problem with BG boosters? If so please enlighten us. As an owner of one of these carbs I'd like to know all I can.
"Some passages I prefer to be smaller to keep velocity and shift recovery up for some applications and putting the drill bit or end mill in reverse doesn't make the hole smaller."
What passages, for instance, would you want to leave smaller than are in the Demon? Do tell. I know of using PVCRs but all of the other passages that I know of are already adjustable on the Demon. Like changeable emulsion tubes and air bleeds for instance. But other than that it kind of leaves me in the dark.
Thanks, Steve
