Old 06-28-2005, 05:00 AM
wnstwolf2 wnstwolf2 is offline
Cobra Make, Engine: FFR 427w
Thanks for the help..
Took another stab at it last night:
fully removed the cable and sent a little lube throught it
made sure the clutch arm had free movement
put cable back on the adjuster at the pedal witht he adjuster loose
attached the cable to the arm at the clutch and adjusted it to the point eh throughout bearing just touched the clutch fingers then backed the adjuster nut off 1/4 turn.
Pedal was a tad lose but tried her out.. worked like a charm.. went for a cruise and slowy adjusted the firewall adjuster to pick up the slack of the pedal (about 2 full turns...)
At the present time all looks great..
thanks again for your help.....ww2
