Old 06-30-2005, 08:16 AM
Terry Stapley's Avatar
Terry Stapley Terry Stapley is offline
Cobra Make, Engine: Shell Valley, 418W, tremec 3550tko, 9" ford rear, 3.0 gear, silver/black
Default Steering shaft
Brent, if I understand what you are attempting on the steering shaft. you are going to weld a flange on the lower end of the top shaft. With this done, will you be able to ever remove the top shaft from the aluminum column to service the bearings if needed?
My SV also has the sleeve that covers the roll pin that is retained with a set screw and after 4000 miles the steering is just as tight as when 0 miles!
Terry
Terry
