Thread: safety wire
Old 07-01-2005, 05:10 AM
Clois Harlan's Avatar
Clois Harlan Clois Harlan is offline
If you are talking about your spinners just drill a 1/16" hole about 1" from the end of the spinner and then another (once you have got them tight with a lead hammer) ahead of the tightening direction of the spinner on the wheel itself. Cut about a 12 or 14" piece of safety wire and thread it through the spinner pulling it thru the hole to equal lengths. With the wire held together with your fingers pull it down to your other hole on your wheel. Attach your safety wire pliers just below your fingers and start pulling the pliers so it twists the wire to about 12 twist per inch. Take the untwisted wire and thread it thru the hole on the wheel and attach your pliers for about 1" of twisted wire. After you have twisted the last piece cut off all but about 3/4 - 1" of the safety wire and with a pair of needle nose pliers roll it under so as not to stick out and scratch someone. Then your done with one wheel and do the other three.
Clois
"Let's roll"
"Be part of Something Good
