Old 07-01-2005, 09:42 AM
rooster rooster is offline
Cobra Make, Engine: shell valley cobra-350 chevy
Hey guys, I have a Shell Valley also and what I did was make a
"D" shaped hole out of the round tube by making a spool like thread comes on out of steel and slicing it lengthwise. Then I milled two slots in the tube for the ridges on the spool to fit into and welded it in on the outside. Then I smoothed it up and you can't even see it. Then I milled a flat on the 3/4 shaft to the right size and it fits perfect. Then I put a 3/16 hardened pin through it just to keep the shaft from pulling out. My steering wheel is now hooked to the wheels with no slop but the components are still removable. Hope this makes sence. Russ
