Old 07-03-2005, 09:48 AM
Dominik's Avatar
Dominik Dominik is offline
Default changes to CR's blueprints
good day,
Nick - you should have told me about this thread!! :-)
while I checked my chassis' rear yesterday I thought about listing changes I (you) did to the Cobra Restorers blueprints.
one comes to mind quickly:
the rear shock absorber (upper) mounts.
cut them flush with the crossmember so that the tire wheel insert sits nicely on the crossmember from shock mount left to tight.
Kirkham did it, so can we ;-)
the scuttle hoop does not seem to be right, I have to look into that.
you defenitely need to get this one right, otherwise you battle with the door hinge mounts, steering mount, support braces to the front pedestals, windshield brackets ...
dominik
If I don't respond anymore, that's because I can't log in
