Tobias, what do the instructions say after that? I haven't used that particular product, but I would expect to start out "failsafe", that is, with minimum additional advance, so the full CW position would provide less advance...it would lock out the vacuujm advace I think. If so, the instructions would then say something about how to adjust it, like "test drive the car in a higher gear, applying throttle quickly under various load conditions; if no pinging is heard, turn the adjusting screw CCW 1/2 turn (or 1 turn, or some amount) and test drive again; continue until light pinging is heard, then turn the adjuster CW 1/4 turn (or some amount) until pinging is not heard under any load or condition".
That procedure is typically done in a higher gear at a "low" RPM, probably 4th gear at maybe 2000-3000 RPM.
Ken
