Thread: Machine Tools
Old 07-04-2005, 02:55 PM
427sharpe's Avatar
427sharpe 427sharpe is offline
Cobra Make, Engine: A CSX Cobra,1966 GT350 and an '06 Ford Heritage GT
As Mick stated, I use the milling machine. Put in a 3/4" roughing bit and feed it to half the diameter and you have a perfect joint for welding IF you have the angle right. I usually measure the set up angle as it will be on the car, than when I mount the vise into the mill bed I use a protractor to set the angle. It gets tougher when you have a compound angle, but the principles are the same except you must use a sine vise to get the compound correct. I have found titanium coated bits as large as 3" that fit my mill (R8 tooling) and I use them on everything. If shoppong for a mill, make sure you get one w/ R8 tooling...it is the spec used by Bridgeport (the main industrial brand) so there are tons of mills and holders available. If true R8, it will also have a 7/16 drawbar...I have seen some sell stuff using a metric thread, which means you would have to buy their bar or make your own.
"I think we have more machinery of government than is necessary, too many parasites living on the labor of the industrious." Thomas Jefferson
