Old 07-05-2005, 11:17 AM
coyled coyled is offline
Scott, that full size windshield does create some down force for the front tires. If you remove it, it will push more in high speed corners, 90 mph or better, but it will only do this at the limit. You will likely have to make adjustments after the removal. If you duct tape off part of the nose, it will help eliminate some of the push. Good luck, Scott.
