Old 07-05-2005, 03:32 PM
alfy65 alfy65 is offline
Cobra Make, Engine: scratch building
Cool Frame
Hey,Thanks guys..i had a case of tunnel vision with that rear end,it's tight but will drop out with bottom mount removed.The camber and toe should be fully adjustable, but will have to assemble shortened axles and A arms to check all out.Mloy's 289 arm is looking good.I might consider building that way instead of CWI style.I set it for stock shock heights (4) and will try to run recommended 2 degree drop on axles at ride height. Alex,I appreciate your insight on frame and thanks again. Yep, forum lookin good
Al
