ERA Wiring Harness Troubles
Hi Bob,
The new wiring harness is installed. As you know I had trouble with the white wire main harness connector (blue plastic plug in) where the two ends plug into together under the dash. No amount of "tweaking" has corrected the problem. Now I also am having trouble with the yellow wire (red plastic plug in). Neither are making a good conection. I have separated all four of the connectors, as previoulsy suggested, and this has not helped. New suggestions?
I have a new alternator and regulator. NOT charging. I took the alternator back and had it tested, it's good. I checked for good grounding at several places, including the regulator, grounds are good, fuses are good. Is it possible the white or yellow MAIN wires are causing the "no charge" condition?
What wires do I "jump" at the alternator or regulater to produce "full charge" from the alternator (for in car testing purposes)?
