Old 07-06-2005, 09:23 PM
boxhead's Avatar
boxhead boxhead is offline
To check if it is LSD or not while it is out of the car it is easiest to turn the pinion flange (where tailshaft bolts too).
And have a friend hold the drive shafts, if it is LSD then both shafts will turn, if it is not then 1 shaft will turn and the other one will be able to be held.
Cruising in 5th
