Old 07-11-2005, 06:09 AM
trularin's Avatar
trularin trularin is offline
Member of the north
Cobra Make, Engine: A Cobra
Open valve cover.
select a rocker that appears to be all the way down.
Unlock the set-screw.
Unscrew the rocker nut ( note the tension on the nut )
turn rocker arm sideways.
pull push rod.
Reverse to install.
make sure you set either lash or hydraulic stop, depending on the lifter used.
Hope this helps
