Speedo Gear Interchange
I broke my original speedometer gear, so I went to the Ford dealer for a replacement. The only 19 tooth gear he had was the pink one in the photo. As you can see, the old one has a longer "snout" and the tooth area is larger. I use the pink one often in Tremec TKO transmissions, but I am unsure if it will work as a replacement for the old one I had.
The transmission is a '73 Ford C4 automatic. Thanks!
kris kincaid
