Old 07-11-2005, 06:19 PM
ffindling's Avatar
ffindling ffindling is offline
Cobra Make, Engine: Findling 001 - starting scratch build
Smile
There are several approaches to dealing
with the lack of distributor when going
to distributorless ignition. Stub
drives are available to drive the oil pump
in the absence of a distributor. If you are
using an ECU that supports true sequential operation as opposed to batch
operation, you'll need a camshaft position
sensor output to the ECU. You can modify a distributor to do this or buy one already built. George Anderson (Gessford) has them available. This approach gives you
the needed oil pump drive and
the camshaft position sensor output for
your ECU.
....Fred
