Old 07-13-2005, 02:01 PM
speed220mph's Avatar
speed220mph speed220mph is offline
Cobra Make, Engine: ERA 427SC w/427so, ERA GT #2002
Jim: I didn't read all of the responses, but I'll just tell you what I know. A good way to wear bores prematurely is run an engine cold. A properly operating thermostat will not cause overheating, but ensure the engine is at operating temperature. The reason it's called operating temperature is that's the temperature at which the engine should operate. Run it colder and bore wear accelerates. I presume the only thing you want to accelerate is your Cobra.
Tom
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough HORSEPOWER." Mark Donohue
