Old 07-13-2005, 04:22 PM
66rdster 66rdster is offline
Cobra Make, Engine: Hurricane #HM1024, 418 Stroker, TKO 600
Hi Jack and Maricopa,
Thanks for the tips. I will definately look into the BBK headers. I too had thought of using the ovalized pipes. With the limited ground clearance every little bit counts. I am looking at all the options right now and I guess I can make a final decision when I finally get my kit. Until I get an engine in the chassis its hard to tell exactly what kind of set up I'll have to use, but a least I'll have several ideas and options. Jack, are you planning on a street version without roll bar etc. and adding bumpers or are you thinking of the SC, just without the sidepipes. Maricopa, I assume the yellow car in your gallery is yours. The exhaust system looks really nice. Its ust what I had in mind. I wish you had a pic of the header setup. Did you make the glove box? It looks excellent. If you made it would mind sharing how you did it?
Thanks for your suggestions.
Mike
