Old 07-16-2005, 10:18 AM
66rdster 66rdster is offline
Cobra Make, Engine: Hurricane #HM1024, 418 Stroker, TKO 600
Default GT40 Crate Engine Questions
Hi All,
I'm fairly new hear and have been enjoying reading through all the information on this site. I am about to order a kit from Hurricane and I have to decide on an engine/trans combo. I am planning on using a T5 transmission, World Class with 2.95 first gear. I have been looking into various crate engines, thinking of building myself and so on. I have been looking at the GT40 - 345HP engine from Ford. I'm not up to date on the Ford stuff and was wondering if anyone could provide any info on the GT40/T5 combo? I am mainly looking for info on what it will take to get this engine in and running. Can the front cover/water pump/balancer be used as is? What type of pulley system? Can it take a mechanical fuel pump or do I need to go with an electric pump? Oil pan usable as is? Does the flywheel that comes with it work with the T5? Stock (aftermarket HP replacement) Mustang clutch work. Bellhousing? Will the intake/carb distributor from the earlier 289/302 engines bolt right up? I guess to sum it up, what is going to take to use this engine? Also, if anyone has any pros or cons on this combo, I'd like to hear about it. Thanks in advance for your responses. I appreciate any info you can provide.
Mike
