Old 07-16-2005, 12:09 PM
FFR428's Avatar
FFR428 FFR428 is offline
Cobra Make, Engine: HM-2027 / 427 SO
The top two are threaded plugs and the bottom one pressed in. You can use some teflon sealer on the threaded plugs. Did you use any sealer on the lip of the cam plug before putting it in? You can use a little around the edge and also to seal it after it's installed. Also a good idea to be sure you have the correct cam plug. I like the Dorman brand. G.
