Old 07-17-2005, 05:11 AM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
Default Re: Melonized Distributor Gear
Originally posted by BossCER
How do you guys feel about a Melonized distributor gear vs. a Bronze gear on a roller cam motor??
A bronze gear, since it is softer, is going to wear faster, without wearing the gear on the cam. With a steel gear , it will last longer, but you are at risk of wearing/destroying the gear on the cam, therfore ruining the cam. I have used a bronze gear in the past, and after 1000 miles, there was noticible wear, but not nearly to the point of gear failure. So I switched to a steel distributor gear, by Crane cams, and after another 1000 miles, there is no noticible wera at all, on either the distributor or cam gears. I have not yet buffed the leading edges on that cam gear yet.
One thing that is not talked about much, but I have noticed myself, is that the gear on my comp cams roller cam ( a different engine) had sharp leading edges on the teeth, so it was recommended by somebody on this forum, and I did, to use a dremel to buff the edges smooth to the touch. I have not yet ran this motor to see how durable it is. I plan on running a steel distributor gear with it as well. I think I remember in that person's post, that they said they do this on all engines they build with roller cams, and have not seen any wear problems. I wonder how much wear I would have had with the bronze distributor gear in the above engine if I had done this to the cam gear. I think it also depends upon the engine design itself, as some engines may get less oil to the teeth when running, and have a predisposition to gear wear/failure, such as the sbf.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
