  #27 (permalink)
Old 07-17-2005, 06:29 PM
Tommy's Avatar
Tommy Tommy is offline
I'll add my personal anecdote just in case someone finds it useful. After rebilding my 351W with aluminum heads, the stainless steel headers on one side leaked after a few hundred miles of use. When I replaced the gasket, I added a generous bead of silcone sealant. I now know that the relatively low torque on the header bolts combined with the thick sealant to allow the headers to stand out from the face the heads. When I started running the engine, the headers rocked back and forth on the bead of sealant and quickly began to leak.
Faced with headers that leaked with two different gasket/sealant combinations, I investigated further. I took the headers to my local machine shop and asked them to check the mounting surface for flatness. Sure enough, the mounting surface was warped. I had them mill the surface flat and remounted the header with a normal gasket, normal torque and safety wired bolts. It hasn't leaked since.
Tommy
Previously owned EM Cobra
