Thread: synthetic oil
Old 07-18-2005, 03:50 PM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
The automotive designers usually call for their engines to run at 212 F oil and water temperature with an oil thickness of 10. This is the viscosity of the oil, not the weight as labeled on the oil can. I want to stay away from those numbers as they are confusing. We are talking about oil thickness, not oil can labeling. This will be discussed later. Forget the numbers on that oil can for now. We are only discussing the thickness of the oil that the engine requires during normal operating conditions.
The engine is designed to run at 212 F at all external temperatures from Alaska to Florida. You can get in your car in Florida in September and drive zig-zag to Alaska arriving in November. The best thing for your engine would be that it was never turned off, you simply kept driving day and night. The oil thickness would be uniform, it would always be 10. In a perfect world the oil thickness would be 10 at all times and all temperatures. If the thickness of oil was 10 when you got in your car in the morning and 10 while driving it would be perfect. You would not have to warm up your engine. You could just get in the car and step on the gas. There would be little wear and tear on your engine, almost none. Unfortunately the world is not perfect.
The night before when you drove home from work the car was up to the correct operating temperature and the oil was the correct thickness, 10. Over night the engine cooled to room temperature and the oil thickened. It is 75 F in the morning now (I do live in Florida). The oil thickness is now around 150. It is too thick to lubricate an engine designed to run with an oil having a thickness of 10.
It is time to introduce the concept of lubrication. Most believe that pressure = lubrication. This is false. Flow = lubrication. If pressure was the thing that somehow lubricated your engine then we would all be using 90 weight oil. Lubrication is used to separate moving parts, to keep them from touching. There is a one to one relationship between flow and separation. If you double the flow you will double the separation pressure in a bearing. The pressure at the bearing entrance is irrelevant. In fact the relationship between pressure and flow is in opposition. If you change your oil to a thicker formula the pressure will go up. It goes up because the resistance to flow is greater and in fact the flow must go down in order for the pressure to go up. They are inversely related. Conversely if you choose a thinner oil then the pressure will go down. This can only occur if the flow has increased.
It seems then that we should all be using the thinnest oil money can buy. This is partly true. Let me use my 575 Ferrari Maranello as an example. I drive this car around town. The manual of this car states the target pressure is 75 PSI at 6,000 RPM. The gold standard is that all engines should have a pressure of 10 PSI for every 1,000 RPM of operation, not more, not less. After all, you do need some pressure to move that oil along, but only enough pressure, not more. More pressure is not better; it can only result from the impedance of oil flow. Remember that oil flow is the only thing that does the lubricating.
Note that Ferrari is not saying what thickness of oil to use. That can only be determined by experimentation. My engine oil temperature is running around 185 F as I drive around town on a hot Florida summer day. I have found that the thinnest oil I can buy that is API / SAE certified is Mobil 1’s thinnest oil. Even with this oil I get 80 PSI at 2,000 RPM. It is too thick for my application yet it is the thinnest oil money can buy. If I was on a hot Florida track in mid-summer the oil temperature would probably get up to 302 F. I will guess that the pressure would only be 40 PSI at 6,000 RPM. The oil I am using would not meet the requirement of 75 PSI at 6,000 RPM from Ferrari. I would have to choose a thicker oil for this racing situation. The oil I use now would be too thin at that very high temperature. (This is only partly true. Higher RPM running engines use thinner and thinner oils to get more and more flow. I will discuss this later).
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
