Old 07-18-2005, 06:31 PM
The Dreamer The Dreamer is offline
Cobra Make, Engine: KMP329 w/KC489 Shelby
Steve,
What is your idle rpm? Mine is at 1000, but I could probably go a little lower, but not much. Also, what air cleaner do you have? I noticed that when I went from the Hellings and Stellings foam to the K&Ns, I don't have the stalling during quick stops. The rpms dip, but the car continues to run and recovers. On the fuel pump, mine does the same thing. I guess the mechanical pump can't pull enough fuel through the electric pump to supply the engine under load. I just keep the electric on at all times and have had no problems.
