Old 07-19-2005, 02:12 PM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
Originally posted by BossCER
both GM and Ford use Melonized gears on their Roller motors. I suppose if it is good enough for two of the Big 3, it should be good enough for me.
Yeah, but do GM and Ford use these gears with factory billet steel roller cams or cast-iron roller cams (or are the gears on their cams billet or cast iron)? Most aftermarket roller cams are billet, so there may be a compatability problem. I'd call your cam manufacturer to see if the distributor gear is compatable.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
