Old 07-20-2005, 09:29 AM
DougD's Avatar
DougD DougD is offline
Cobra Make, Engine: Sold my beloved Shelby CSX 4068, Gessford 427 Ford
I just put this exact engine into my '87 Mustang.
To answer your questions for a Cobra:
The front cover is ok unless you want to use a mechanical pump, then you'll have to change to an older style.
The water pump is a Mustang serpentine reverse-flow type. You'll need to change that.
No pulleys come w/this engine. The balancer is std '82-up small block 50-oz imbalance. Put on your pulleys and go.
The oil pan should work. It's a std Fox Mustang rear sump with a left (driver's) side dipstick.
The flywheel should work fine and a std Mustang clutch will fit.
Bellhousing can be late Mustang or aftermarket scatter shield.
Intake/carb will fit. Distributor must have a bronze gear to fit the roller cam.
This is a great little engine for the price. Make sure you get the latest version that has the roller rockers and aluminum valve covers.
CSX4068, '69 Bronco, '70 BOSS 302, '87 Mustang GT, '08 Roush Trak Pak
