Thread: AFR 165 Advice
Old 07-21-2005, 10:55 AM
66rdster 66rdster is offline
Cobra Make, Engine: Hurricane #HM1024, 418 Stroker, TKO 600
Hi,
I thought I would add my .02 about the AFR's requiring modifications. I don't know if this is the case here or not, but the 165 and 185 AFR's have the exhaust ports in the stock location. The 205's and 225's have raised exhaust ports for better flow which probably would require some slight tweeking of the exhaust system for everything to line up. I don't know if this is the case on the Cobra exhaust or not but a friend of mine had experienced this same problem when going from the 185's to the 205's on his Mustang. He went from the stock heads to the 185's with no exhaust system modoifications but had to do some minor mods going to the larger heads. IMHO the smaller 165 and 185 AFR's should fit just fine.
Mike
